Generate Unique IDs as GlobalID when appending a FC without GlobalIDs to one with GlobalIDs
1216
11-16-2025 11:41 PM
Status: Implemented
MarkusWall1
When appending features from a feature class not having a globalID field to one with a globalID field, all the importet features get the same globalID.
It ist impossible to work with this data afterwards, so the features have to be deleted.
At least a warning would be fine, that the origin data has no globalIDs and that they should be generated before appending the features.
Tags (3)
5 Comments
KevinSaavedra
Hello,
In Pro 3.6, I appended a file gdb input feature class with no globalIDs to a target feature class with globalIDs and the appended features were all assigned new globalIDs.
I also verified this is the case when the input feature class is in a file gdb and the target is in a SQL Server eGDB.
Could you please list more detail about your case where the same globalID is used for all appended features?
MarkusWall1
Hello,
I was able to reproduce it a few times last week, but it's not reproducible now.
What I figured out is, that when the option "preserver GlobalIDs" is set, the GlobalID of all importet objects is the same, but its {00000000-0000-0000-0000-000000000000}
I found an older screenshot from August, where I documented the problem with the same GlobalID after an import.
BR,
Markus
Origin FCOrigin FColder screenshot of appended dataolder screenshot of appended dataTarget FCTarget FC
KevinSaavedra
This is implemented in Pro 3.7. If the target dataset contains a Global ID field and the input data does not, running Append with the Preserve Global IDs environment set to True will automatically generate new Global ID values for inserted rows.
MargaretCrawford
MargaretCrawford
