Field edit errors should detail the attribute rule name used (Error 002810)
2176
02-06-2024 10:20 AM
Status: Implemented
NickAddison
Sometimes things need to be changed within the fields, that results in Error 002810: "The field is used by an attribute rule." It would be amazing if the error message or a popup window could detail which attribute rules are being used by the field trying to be edited. This would save so much time and frustration. As is, you have to iterate over every single line of code looking for the field name; which can be tedious when you have a litany of attribute rules or lengthy lines of code.
Edit: Another way to resolve this would be via an attribute rule search bar.
5 Comments
MErikReedAugusta
Honestly, I think both Ideas are worth implementing.  I'd love a search bar AND I'd love a more-verbose error message, here.
SSWoodward
@NickAddison, thanks for the Ideas!
The team agrees that this idea is worth considering, so we're changing the idea's status to 'Under Consideration'. The idea under consideration for this post is for more verbose error messaging that includes the name of the limiting attribute rule.
In order for us to be able to properly manage these ideas and update users about their status, please consider opening a unique idea requesting a search bar in the attribute rules design view.
SSWoodward
SSWoodward
KoryKramer
This is implemented in ArcGIS Pro 3.4. Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
