Feature Class Properties dialog in 10.3 (ArcMap and Pro)
865
02-10-2015 11:35 AM
Status: Closed
RenatoSalvaleon
Please make it available in ArcMap Catalog and ArcGIS Pro Project Pane. Since 10.x, when Catalog was introduced in ArcMap, the the menu item in the right context menu disappeared. It was was carried over into Pro and the only way to retrieve it in both ArcMap and Pro is to add the data on the map.
Should not be that difficult to make it available in the Catalog or the Project panel.
2 Comments
KoryKramer
Feature class properties from the context menu?
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to duplicate Data Management Idea
