In Export Layout, the output location is automatically set to the project folder, but most of the time, I want to export to a nested output folder within that project folder. It would be helpful to have the option to specify a dynamic file path to export layouts to. For example, instead of ...\ProjectFolder\Layout.pdf, it would default to ...\ProjectFolder\Output\Layout.pdf
Note that this wouldn't be a single default location where everything would land. The ellipses in the example paths above would be the dynamic part, so if you have projects in disparate locations on your network, this would export to a folder with the name of your choice within the Home Folder of your project no matter where that project is.
