Enhance the "Geoprocessing History menu"
709
12-20-2020 07:52 AM
Status: Open
MarcSwartz
The Idea is to add an additional Right click Menu item to the Geoprocessing History menu.  It could be labeled as: Copy Python Command with Env
It would Copy the Python command and open a checkbox selection list of the environment variables to also be copied.  The checkbox list should include top level option like:
  1. Environments use with Geoprocessing tool
  2. Non Default Environment
  3. All selected Environments
Say we run a geoprocess task that includes a Processing Extent and we use the "Current Display Extent" option.
The Copy Python Command with Env could return the selected Environments Python commands and the Geoprocessing tool's Python command.  (simple example)
arcpy.env.extent = arcpy.Extent(936212.76, 655875.41, 938212.76, 656875.41)
arcpy.cartography.AggregatePoints("InData_11","Outdata_11_AggregatePoint", "10 Feet")
For the way I work, this would be a big time saver and reduce errors.  It would also be a great learning/teaching resource into the arcpy.env world.
Thanks All.
