Enable ArcGIS Pro to Print a Table
6235
13
08-24-2021 08:53 AM
Status: Implemented
DavidWheelock2
Please enable ArcGIS Pro to print a table.  I don't need to create a layout or create a new artifact within my Pro project.  I just want to print the table, like I can in ArcMap.
In ArcMap, I can open a table and go to the Options menu and select Print.  It's just an unformatted printed and that's OK.   I've hunted and hunted and cannot find this in Pro.
13 Comments
DavidWheelock2
Thanks @KoryKramer.  It's good to have this feature.
I just tested this item.  It took about 1 1/2 minutes to generate a print job where I had selected 6 records out of a table of about 58,000 records.  1 1/2 minutes to print 6 records in text format seems kind of sluggish.  Is there room for improvement there?
KoryKramer
@DavidWheelock2 quick question - do you see the lag the first time you you choose a printer/first time you try to print a table in a project? If you open the print dialog again do you see the same lag?
DavidWheelock2
@KoryKramer
Yes, I get same result on the second try within a session as I did the first time.
I refined my testing and tested in a simple ArcGIS Pro project.  My initial test result of ~90 seconds was with a very heavy project with lots of layers.  When I tested in a simple project, the time to generate the print job was about 30 seconds.  That's much better than 90 seconds, but still 15 times longer than ArcMap's 2 seconds.
