Enable ArcGis Explorer to read map packages
3159
07-14-2011 04:31 PM
Status: Closed
DanaKern
When creating a package from ArcMap 10.0, the package can be uploaded to ArcGIS Online, my content, or saved to a file.
However, ArcGIS Explorer does not support the map package (mpk) format, only layer package (lpk) format.
The idea: We should enable ArcGIS Explorer to read mpk's.
Example: User X utilizes ArcMap and creates and edits all of the maps for the company. User Y needs to view the maps  but only has ArcGIS Explorer available to them.
User X should be able to upload mpk's to ArcGIS Explorer so that user Y is able to view the maps.
By utilizing mpk's rather than lpk's it will display the entire map that user X  has created without having to group all the layers and create layer packages.
4 Comments
SarahGreenlaw
This is a VERY good idea! I have to go back & forth creating the layers in ArcMap, then bringing them all individually into ArcGIS Explorer.. and it would be so much easier to set it up without a dual system.
WilGorr1
ArcExplorer Online does not even let you include a layer package in a map. You can only view an online layer package in ArcGIS Desktop.
JulianInskip
Good idea.
What I normally do is to create a group of all my layers in my MXD then create a Layer Package of that group. I can then add it into ArcGIS Explorer Desktop.
ValeriaChavez
Status changed to: Closed
Hi @DanaKern
ArcGIS Explorer Desktop is retired as of Oct 1, 2017.  As a retired product there will be no new development, patches/bug fixes, or live technical support.
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS.
