Editable MXD Files
4047
8
06-23-2010 02:05 PM
Status: Closed
RandalHale
Waaaaay back in Arcview 3.x you could open an .apr file in notepad (or VI - mwahaha) and fix it if something happened. Now - you've got squat if your mxd goes south. Heck you can even edit a Quantum GIS project file if something goes wrong....not that I have or would use Quantum GIS - I know a guy who knows a guy who said you could...... . So make the mxd a xml/text based file  you can fix. I want to open my MXD in vim.
8 Comments
CraigBarraclough1
Text based files also give you the ability to globally change paths rapidly.
KeithGemeinhart
Yes, yes, yes! If I could upvote this a million times I would. ArcGIS explorer uses XML to save files, let's get that feature into ArcMap too!
mattwilkie
we could have the best of both, text for editability and comprehension, and binary for speed and size, by using binary xml.
See http://www.cubewerx.com/bxm, "a straightforward, open, patent-unencumbered binary-encoding format for XML data that is a stand-alone work-alike drop-in replacement for an XML file that mirrors the XML markup structures in a way that is similar to the in-memory representations of many parser libraries." and "Initial testing indicates that CWXML is 3 or more times faster at parsing XML (text data) than other popular libraries such as expat and libxml2 (10x Xerces) and 5 to 60 times faster again at parsing BXML data. The library is being developed by CubeWerx as the reference implementation for the BXML proposed specification."
StefanFreelan1
OR, if not a text file, give us a simple tool that can read and edit a .mxd file in it's current format.
NinaSavar
I second, third, fourth, this suggestion.
MichaelJeffrey
This would be an easy way to edit things that aren't exposed via arcpy
TrippCorbin
With ArcGIS Pro working to replace ArcMap in the future maybe this would be something we could suggest for it ArcGIS Pro Project files instead since MXDs may not be around long.
ValeriaChavez
Status changed to: Closed
Hi @RandalHale
ArcGIS Desktop retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application.
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
