Edit or Add Field Sequence for Locator Field Search, Suggestions, and Outputs
202
03-05-2025 11:02 PM
Status: Open
RanaDas
When creating organization-level address locator from ArcGIS Pro, there may be scenarios where the field sequence for output results in a locator needs to be modified or changed. Additionally, the organization may require an extra field for searching or retrieving output.
If Esri could add a functionality that allows users to define which fields should be used for searching, which fields should participate in generating suggestions, and which fields should be included in the output, it would be highly beneficial. This enhancement would help meet customized business requirements more effectively.
