Dynamic symbol size
38
6 hours ago
Status: Open
GregoireCatineau
The ability to have symbols whose size adjusts based on the zoom level.
For example, a square symbol representing a tile grid cell that scales dynamically with the zoom, so that it remains proportional to other displayed elements at any scale.
1 Comment
Debert
Hi @GregoireCatineau,
If I understand your request, this is very achievable using ArcGIS Pro.
There are a few different workflows, depending on if you would like to set the dynamic scale for a layer or rather a specific feature layer.
To set the dynamic scale for an entire layer, simply navigate to the layer in the contents pane > Right-click > Properties > Under Properties pop-up, select General and you'll see Visible Scale Range (choose 'Show layer between these scales only). Then specify the Maximum and Minimum scales.
Lastly, if you have a layer with 'Unique Value Symbology' and you want a specific feature to dynamically scale
Lastly, if you have a layer with 'Unique Value Symbology' and want only a specific class/feature to dynamically scale choose Format Symbol > Properties > Symbol > choose 'Enable scale-based sizing.'
From there, you can customize the size of the symbol at multiple different zoom levels.
I'll share a video below for easier understanding.
arcgis-pro-tips-scale-based-symbol-sizing
Cheers!
