Drop down menu selection and drag and drop functionality for Sharing Selected Layer as a Web Layer
1756
7
02-11-2025 01:34 PM
Status: Open
Ed_
by MVP Regular Contributor
Let's say a feature class is published and then another feature class of the same project needs to be published as well. So, if there's a drop down option, then that next layer can be selected, and most of the parameters like sharing level, project folder, tags and group selection can stay the same. Thus saving some time and clicks
Tags (1)
7 Comments
JonahLay
Thanks @Ed_, for submitting this idea. Can you please review this idea to see if it covers your requirements? It is a bit similar: https://community.esri.com/t5/arcgis-pro-ideas/set-your-own-defaults-for-service-publishing/idi-p/92...
Ed_
Hi Jonah, thank you for sharing that, but not really since that OP's idea seems much more broader
JonahLay
Status changed to: Open
Ed_
I also saw that needs clarification has been added to the idea as well. Well, what i was trying to say was that say a project has five layers to be published, so you publish the first layer by setting up tags, sharing level, folder and group. Most of the times these parameters will stay the same for the other four layers as well, so it would be nice to have a drop down menu option right under item details, so that you can just select the second layer to be published, and these parameters will stay the same. This will save the user from right clicking on next layer under Content > Sharing > Publish as Web Layer > Setup those parameters again. Summary will be carried over from the metadata or the user can type it; same goes for the title as well, so no worries on that.
Ed_
Does that make sense now?
JonahLay
Thank you, yes. I changed this idea to open to allow others to add kudos.
Ed_
Cheers 🙂
