Drag GDB from Catalog to GP parameter — Suffix path with .GDB
607
04-22-2024 01:15 PM
Status: Open
Bud
Legendary Contributor
ArcGIS Pro 3.2.2
When I copy a geodatabase path from Catalog using the Copy Path context-menu option, the path includes .gdb:
However, if I drag the geodatabase from Catalog down to the Geoprocessing pane tab, then into the GP tool parameter, the resulting path doesn't include .gdb, so it is automatically suffixed with .shp.
Use Catalog Pane to enter GP Input parameter
Could that behavior be changed so that dragging and dropping behaves the same way as Copy Path, so that the full geodatabase path is brought over including .gdb? That would be more useful and consistent.
