Do Not Activate ArcGIS Pro Window While Loading if User has Switched Applications
15093
41
05-04-2021 03:36 PM
Status: Open
NathanHeickLACSD
Well, I'm not versed in the proper terminology for this, but I hate it when I open ArcGIS Pro and start it loading up and then I switch to another app to do work in the mean time.  Routinely, it will reactivate ArcGIS Pro, what seems like multiple times.  If I switch from ArcGIS Pro to another app while it is loading, it should keep loading in the background and not reactivate itself.
41 Comments
RTPL_AU
@Rayn
For the last few versions it seems to come & go as you update Pro, .Net, and other Windows' components.
I get the impression something is broken in the Pro <> Windows integration and I've now seen it behave differently on different machines while the same version of Pro is installed.  As mentioned in elsewhere, I think this is affected by a change in Windows or Pro - not the actual update/upgrade/patch, but the fact that something changes triggers this behaviour.
At the moment, for me, with 3.5.4 and 3.6 it seems better - due to the number of times I restart 3.5 & 3.6 a day to avoid the slowdowns and copy-freezes, I am very glad I'm not seeing this behaviour!!
