Display radius of arc
1187
11-08-2010 02:18 AM
Status: Open
AxelOrth
When creating an arc you can use 'r' to enter the radius.
BUT there is no way to get this information afterwards.
I think this information is useful enough to be displayed.
Cheers
Axel Orth,
LGV Hamburg,
Germany
Tags (3)
2 Comments
MikeGill2
Good idea that will become more important as move to geodesign
ReneeJudkins1
First, Put your line in edit mode.  Then, open the traverse window on the COGO toolbar and right click in the blank window. Then you can opt for Load Traverse from sketch.  That way you can see all of the information for the line that is being edited.  I think this is pretty much the only option and has been for a while.  Also, if you set up the correct fields in the attribute table then you can store the cogo information that you used to create the line with.  I hope this helps!
