Display attribute dialog after storing new features
5257
11
08-04-2020 11:42 AM
Status: Open
JakubSisak
Honored Contributor
Please consider adding the "Display attribute dialog after storing new features" Editing Options feature from ArcMap into PRO.   Setting the attribute value in Templates doesn't really cut it. Configure a feature template—ArcGIS Pro | Documentation This is only a crude work-around and does not come close to an intuitive pop-up dialog that's available in ArcMap. This feature is extremely useful when creating 100s or 1000s features with many different attribute values.
11 Comments
משהגוטמן
Hi all,
I’m not sure whether this is part of a recent update or something we’ve just missed so far in ArcPro (myself included).
I’ve just discovered the option to prompt for table attributes as part of a template. Once you check the box in the template properties, the attribute appears in the Create Feature window as an input that you can easily change for all subsequent features (see pics).
It’s not exactly the same as having the attribute window pop up after each feature, but I’ve found it convenient enough.
