Disable/Enable Sequence Table(s)
283
08-22-2024 09:44 AM
Status: Open
MHeadley
Sometimes you want to create test data, test attribute rules, or might need to buffer several features and then merge those buffers into one feature, without wasting valid sequence numbers during the process. Setting up a testing environment or a secondary workspace can be time consuming. With Attribute Assistant you could turn on/off the tool - could there be something similar for disabling/enabling the sequence tables (quickly without going into the database and disabling the rules)?
Tags (1)
