Default Legend Item Properties
1292
11-16-2012 09:14 PM
Status: Closed
GIS-Cambria
Occasional Contributor II
Please consider an option to allow a user to define default legend iterm properties such as font settings and visibility for current extent even if there are no layers present in the map. This is very necessary for creating map templates that have empty data frames. It is also necessary for using the new export map GP tool for ArcServer 10.1 with custom templates. Blank templates are very useful for both ArcMap and ArcServer, but setting legend properties without a layer is not currently possible. Also, if a layer is used to set the properties and then removed and the blank template is saved, the settings are lost.
 0EME0000000TU0J
2 Comments
MichaelKnight2
Yes, please make this available in ArcMap. It is a total pain if I want to change the font or the color of the text in my legend to have to do it for every layer plus any new layer I may add.
AubriKinghorn
Status changed to: Closed
Closing, as this is available in ArcGIS Pro with default legend items and legend item styles. Learn more here: Work with a legend item
