ctrl-z in Pro
1434
12-22-2016 01:07 PM
Status: Open
PaulStephenson
I've noticed that ctrl-z doesn't clear / undo text when editing domains in ArcGIS Pro - maybe across the board. Would be handy!
Thanks
Paul
1 Comment
Robert_LeClair
Hi Paul - I'm looking at the ArcMap shortcut keys for editing and vertices (see images below) and they're identical - even with the factory default of CTRL-Z.  I'm wondering if the CTRL-Z shortcut key got reassigned by local users in the ArcMap days to delete vertices?  As it is, it does make sense that a CTRL-Z (which in an undo) would undo the edit. If you use the D key and click a vertex, it deletes a single vertex.  If you hold down the D key, you can delete a group of vertices using a lasso.
ArcGIS Pro CTRL+ZArcGIS Pro CTRL+ZArcMap CTRL+ZArcMap CTRL+ZArcGIS Pro Vertices shortcutsArcGIS Pro Vertices shortcutsArcMap Vertices shortcutArcMap Vertices shortcut
