Create Steepest Path tool missing in ArcGIS Pro
3731
11-22-2018 06:07 AM
Status: Implemented
KjetilSverdrup-Thygeson
This 3D Analyst interactive tool in ArcMap is greatly missed in Pro.
We are working manly with natural hazards, such as avalanches and rockfall, and this tool is vital for us.
5 Comments
mgswartz1
Yes the interactive tool is missed.  I say not only should it be return, but they should add it as a  geoprocessing tool also, to make it programmable.
KoryKramer
@mgswartz1 please be sure to add your kudos to the idea so your support gets counted. Thank you!
NathanShephard
NathanShephard
This tool is included in Pro 3.5!  It has been added into the Exploratory 3D Analysis drop down gallery list on the Analysis ribbon tab for 3D views.  🙂
There will be more detail in the Help, but figured I'd mention that we took this opportunity to allow you to set the sampled resolution of the ground surface, as well as an optional Maximum Rise property, to help you get the steepest path result to get past small blockages in its path - example below (with the path able to get past an up-to-5m-rise).
Run 1 - path goes 3kmRun 1 - path goes 3km  Run 2 - path goes 11kmRun 2 - path goes 11km
We also let you see the profile graph for the result, export the line to a feature, and so on.
Hope this helps with your work!
-Nathan.
ValeriaChavez
Hi @KjetilSverdrup-Thygeson! This Idea was implemented with the ArcGIS Pro 3.5 release with the. You can learn more about it on the Interactive steepest path page of the documentation. Checkout the Your Ideas in ArcGIS Pro 3.5 blog on Esri Community to learn about other Ideas implemented with this release.
