Create Data Types INSIDE ArcMap
529
06-22-2010 11:06 AM
Status: Closed
JeromeParkin
ESRI please add:
'Create Shapefile' [Point,Line,Polygon] +set datum/projection
'Create Geodatabase' [All known data types] +set datum/projection
INSIDE ARCMAP [for the 10th time of asking]
(Like Arctoolbox merge ArcCatalog & ArcMap into one)
And when EDITING a table in ArcMAP please allow a new field to be created without requiring to be NOT editing the table.
Curreent Solution
http://www.ian-ko.com/
Geowizards 9.9 [soon to be 10] can do this and much more for free.
2 Comments
DavidKnudsen
ArcToolbox already allows you to create new shapefiles, feature classes, and geodatabases from within ArcMap, even in version 9.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/create-data-types-inside-arcmap/idi-p/921738
