Create an interface for adjusting label classes en masse
760
09-23-2021 09:04 AM
Status: Open
wayfaringrob
Honored Contributor
I always have a hard time adjusting label classes - when I realize I want to merge some, for example, it's a matter of opening one of them, adjusting the SQL statement, renaming it, going to the other one, removing it...ah!
I'm picturing an interface like the one for symbology classes, where you can easily group classes, rename, and remove them. Right now, the labeling options are strewn across the UI - there's the label properties pane (which itself contains myriad tabs and subtabs), pop-up boxes for things like weights and priorities, the list by labeling TOC, the labeling tab...consolidating labeling into fewer disparate UI elements would be appreciated.
