Control Shift Select all layers
508
11-26-2025 07:14 AM
Status: Open
Miralem_Zeljo
Please add functionality that allows users to hold Ctrl + Shift and select all layers at once, similar to how clicking inside a group checkbox selects everything within it. This enhancement should enable selecting layers both inside groups and outside groups simultaneously.
Implementing this consistently across the application would greatly improve usability. The ability to toggle visibility for all layers and modify properties for all selected items at once would provide a significant productivity boost for everyone.
1 Comment
SarahMorrison
Hi Miralem,
Is this much different than the ability to hold shift and click on a range of layers? In your contents pane, similar to desktop, you can hold shift, click the first and last layer, and it'll select everything in between. It will select groups, and maybe not everything within a group, but selecting the group allows for the full group to be turned off or on. Different layers have different properties, so I understand why you can't see uniform symbology windows (as an example) if you select everything in your map because there's too much variability for layer types - are you looking to be able to make - for example - all polygons be symbolized the same?
