Contents Pane: List by Visibility or Select Layers by Visibility in order to clean up the pane by Grouping or Removing layers
2359
10-13-2023 10:36 AM
Status: Already Offered
MapMan1
In the Contents pane it would be really nice to be able to either sort the layers by visibility or if there was a "List by Visibility" tab on the pane. This way when I have a project with a WHOLE bunch of layers and I get the project to the final stage, then I could select all the layers that are turned off and remove them from the project or Group them so I can minimize that list of layers.
It would really help with cleaning up projects to be able to select all the layers that aren't currently visible and either remove them or "Group" them so I could clean up the contents pane.
4 Comments
KoryKramer
What about just filtering Visible layers?
Is that what you're asking for, or something else?
KoryKramer
@MapMan1 does using the Visible filter work for you?
KoryKramer
Status changed to: Closed
Per the comments above, I believe that the Contents pane Visibility filter will accomplish what is being requested.
KoryKramer
