Combining Spatial and Thematic Map Series, adding flexibility to the layout
1448
08-07-2024 03:37 AM
Status: Open
Ainfa
Hello everyone,
I am currently working on an urban planning inquiry where I have to analyze about 300 areas and produce A3 layouts for each of them. Each layout consists of 5 different map frames representing different urban planning instruments that insists on the area under consideration. I managed to link the map frames together so that through a spatial Map series applied to the first frame the others also frame the same area.
Now however, wanting to show only some features insisting on the area under analysis and not all the others of a certain shapefile, I created for each area a radio group using the "layer from selection" tool. It would be very useful at this point to be able to apply to each layout in the series a "subseries" of the thematic type, so that i could both zoom-spatially and activate-only what i need to see. At the moment, before exporting each layout, I have to select manually for each map frame the radio group element to be shown.
In addition, wanting to customize some elements of the individual layout, such as a text, I don't understand how can I do to release it from the series, so that it doesn't also change it in all other layouts. Finding these obstacles for now I am solving by duplicating a standard layout and fixing it each time manually.
I hope I've been able to explain myself, thank you for the consideration.
2 Comments
JonBennett
I have been using the new thematic pages quite a bit and it would be even better if an option was added to change the spatial extent and control what items are shown in the Layout. I'm not sure how this could be done - it would be a combination of thematic and data driven pages essentially. I know this can be done through a combination of data driven pages and page definition queries but this can be difficult to setup. Currently i'm having to use multiple Layouts of different extents in conjunction with thematic pages.
Additionally an option to include/exclude items in the Layout based on thematic pages would be very helpful
AlfredBaldenweck
This would be really sweet.
For example, if I need to do print a layout for 8 different species across 5 specific areas.
If I could set it up to iterate spatially (or through bookmarks, whatever) through each of those 5 focal areas, and then do a layout for each species, it'd save a lot of time.
Something like:
  1. Area A: Jackrabbit
  2. Area A: Prairie Falcon
  3. Area A: Groundhog
  4. Area A: Rattlesnake
  5. Area A: Beaver
  6. Area B: Jackrabbit
  7. ...
I'd be able to get 40 pages to print with very little effort.
The current way to do this is to manually go to each index feature (or bookmark) export the thematic map series, and then go to the next index feature. It'd be really great to just let Pro do all the work.
