My preference when using field calculator, among other tools, is to use Arcade rather than Python. However, ArcGIS Pro appears to retain a default to Python. While I don't see an option to swap the default in ArcGIS Pro's options, it doesn't mean it isn't there somewhere. But if it is not an option, it would be an appreciated update.
Thanks for looking
This is implemented in ArcGIS Pro 3.3 using the new parameter override capability https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/run-geoprocessing-tools....
See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
Hi @JeffreySchmidt3000 , I want to share a new blog post about this enhancement!
The blog takes you through the steps you can use to change the default expression type in Calculate Field from Python to Arcade:
Hello @MargaretCrawford
If I'm understanding this correctly the ability to change the expression type only exist in the Geoprocessing Tool, not the field calculate option in the table? Is there a way to change the default option when selecting field calculate from the table?
Thank you for any input
Hi WardMitchell2,
I used the setting described in MargaretCrawford's post and it also sets Arcade as default (only) in the fieldcalculator as well.
Only thing I encountered is when in Modelbuilder the field calculator defaults to Python
@Gisbert61 @MargaretCrawford @WardMitchell2 please see below. If altering the config file does change the Calculate feature located in the Attribute Table, that is what is desired.
Will changing the config file alter the "Calculate" option in the Attribute table?
Yes, @CU-KeithJones, both 1 and 2 now default to Arcade. In fact I cannot use SQL or Python anymore (which is fine by me but your miles may vary )
But in Modelbuilder I still can choose between Arcade, Python and even VBscript:
Can changing the default Expression Type, just be added under Options? I don't really want to tell all users to just edit their "Pro.settingsConfig" file, so I know the next thing I will get is an email, saying they broke it.
