Change User Experience for Select By Attributes
1728
05-28-2021 03:26 PM
Status: Implemented
NathanHeickLACSD
Occasional Contributor III
When using the Select by Attributes command, I am annoyed by always having to click New expression.  In fact, I see no reason why you couldn't just eliminate it altogether and default to the Create a new expression option where you use pull-down menus to build your query.  If you want to use SQL, there is a slider.  If you want to load an expression, there is a load option.  So, what is the point of this button?  To me, there is no value added and just time wasted.
5 Comments
GIS_MJ
I second this idea!
KoryKramer
KoryKramer
The Select by Attributes user experience was changed in ArcGIS Pro 2.9 based on this request.
See Ideas in ArcGIS Pro 2.9 for this and many other ideas you can expect when you update.
Go to 3:32 in the video.
NathanHeickLACSD
Thanks Kory!
KoryKramer
On behalf of the dev team that took your idea and made it happen, you're welcome!
Thanks for actively participating in ArcGIS Ideas!
