Change selection checkbox to default 'off' instead of 'on' in ArcMap layers
871
05-25-2010 10:12 AM
Status: Closed
CarolDoering
Currently, when you add a new layer to your TOC it automatically appears in the Selection tab with the checkbox turned 'ON'. This can be problematic when you start editing because you can inadvertantly edit features in layers by unintentionally selecting features in layers that you did not intend to edit. For people who use ArcGIS frequently and do a lot of editing this is obvious and easy to avoid but for users who edit only occasionally they often forget to uncheck the selection of layers they are not interested in. To avoid this issue it would be much safer (for the data) to have new layers automatically unchecked for selection when they are added to the map document. That way the user would have to intentionally turn on the selection of the specific layer(s) they are interested in. Alternatively, a setting that could be set for each user would allow them to control the default behavour to 'ON' or 'OFF' to suit their needs.
Tags (1)
2 Comments
KoryKramer
If the main problem is with inadvertently editing, there is a setting in ArcGIS Pro called 'Make newly added layers editable by default'
Unchecking that will ensure that you do not inadvertently edit layers - it will be necessary to explicitly check layers to make them editable.
ValeriaChavez
Status changed to: Closed
Hi @CarolDoering
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application.
The functionality you are requesting is available in ArcGIS Pro as described in the comments by my colleague @KoryKramer  .
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
