For years I've had a working directory containing many Pro projects with the home folder being set to the working subdirectory for each project. In the past there was ONE and only one \Index folder that Pro used for all the projects in my working directory and each Pro project had a subdirectory within \Index. Since upgrading to ver 3.2.0, Pro has begun making a new index folder for EVERY project (\<projectName>_index) at the root of the working directory, which quickly makes the working folder incredibly cluttered. I've looked around in Options for a way to tell Pro where to put the index folders without having any luck. An online search produces the info below, which implies that for some reason this is intentional:
(from How projects are indexed—ArcGIS Pro | Documentation)
The project index for each project is stored in the project's home folder in a folder named <project name>_index. This folder may contain three subfolders:
I would like to see the individual project index folders be, once again, stored in the <home_folder>\Index subdirectory.
Agree! I don't find any improvement with this kind of 're-organization' (?) except complicating the maintenance of folders for the user. It would be really useful to revert.
More than one index file is cluttering the project directory. Esri, please fix this. Thanks.
100% agree! Please fix this.
The amount of annoying this is is insane. I haven't updated one of my machines to the latest, but could you imagine how annoying it would be if all of these had an Index folder??
Looks like this is in the plan to be changed, but I just want to add that this change is annoying and just makes my folders more cluttered. I support wildland fires and we have a folder setup that normally wouldn't have been too bad with a single index folder. Below is an example of one incident I supported last year as an example of why I want this changed back.
