Change Icon for Python scripts in Toolbox
1409
9
07-29-2020 10:33 PM
Status: Open
TimJohnston3
New Contributor III
Instead of a piece of paper, what about using a different color icon for python scripts.  I propose an ESRI blue hammer.
Image of Proposed Icon Change
9 Comments
diggeo2020
I would go one step further. currently we are able to set thumbnails for python based toolboxes. these "thumbnails" should be shown as the icon in the toolbox. a workflow should have its custom icon, , otheriwse showing always hammers or "scripts"will not add any value to the users.
DanGreene
The above is a great idea.  The tools in a created custom toolbox always have the "piece of paper" script looking icon.  It would be great if when selecting properties, I could add my own custom icon for each tool in my own toolbox.  This would go a long way to alleviating the pain of no longer being able to create an ADD-IN with python.
Current Add In
Toolbox in PRO - love to replace the script icons with the above ADD-IN icons
Dan
SeaRM
In ArcGIS Pro 3.2 there is an opportunity to add your own icon to tools, scripts, and models in My toolboxes.
DanGreene
SeaRM,
Thanks for the example.  I gave this a try:
Yet it still shows the script icon so the icon may be too large or the wrong format.  I assume there are some specifications for the format when creating your own script icon.
I was hoping I could make it look like and think the answer may be to downsize the icon.
DanGreene_3-1706846373520.pngR2Calcs
Dan
SeaRM
@DanGreene
Yes, you're right. It still looks as an ordinary script icon in Toolboxes. But I try to add it to Analysis Gallery and I can see my icon there.
(I tried to repeat your icon)
EsriQruqs
I would suggest combining the hammer with the Python logo. You can see it's a "tool" and you can see it's based on Python. Best of both worlds.
DanGreene
Hi EsriQrugs,
I am not sure I understand what you are saying.  My objective is to use my own custom icons and not ESRI icons.  Each tool needs a different icon.
Dan
DanGreene
Hi all,
I tried adding this icon from the PRO image library -
It is also a PNG icon and I got the same result - the tool icon did not change.  I also reduced my original PNG icon in size and that did not work either.
So, at this point my conclusion is that this is a bug.  But I certainly could be wrong about that.  This would be very cool if it would work - custom icons for custom tools.
Dan
DanGreene
OK - not a bug - just implemented differently than I expected.
