Idea Edited 2023-03-17
In the Catalog View:
Database views are currently categorized as tables in the Type column. And annotation FCs are categorized as feature classes.
Those categorizations seem misleading. Could they be changed to better reflect those object types?
There might be other kinds of objects that aren't categorized specifically enough in mobile geodatabases too. I haven't tested them all. See mobile geodatabase datasets for a list.
Related: Filter Catalog by object type
Hello @Bud , what you are suggesting is already offered in ArcGIS Pro. If you would widen the Type column in the Catalog view, you will see that the Type string for feature classes, tables, and so on, are indeed distinct:
I've edited the idea so that it's specifically about database views and annotation. Could this idea be re-opened? Thanks.
I checked with support and they say it's working as designed. So I think that means this is a legitimate idea, not a bug.
Esri Canada Case #03294188
The scenario that you have described with views in a mobile geodatabase stored as a Mobile geodatabase table is an expected behaviour. The data you add to a mobile geodatabase can be stored in the following dataset types:
- Tables (nonspatial)
- Feature classes
- Relationship classes
- Feature datasets
For the views you have created, it is non-spatial so they will be stored as a mobile geodatabase table.
This web link shows all the dataset types for a mobile geodatabase: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-mobile-gdb/mobile-geodatabase...
Related: Clarify the docs: Mobile GDB Dataset Types — Views
ENH-000156877
In ArcGIS Pro geodatabases (Enterprise, File or Mobile) views are categorized as table in the Catalog View type column
Thanks for the idea @Bud
This looks a lot like an idea that is already in product plan:
Link - Pro Catalog Sort by Feature Geometry
Let us know if that idea meets the needs of your request to specify the feature type of each feature class in the catalog (anno, point, line, view etc) and we can merge.
The behavior you're seeing with unregistered mobile geodatabase spatial views showing as non-spatial tables is a known bug.
BUG-000157223 - The View Icon shows as Standalone table instead as Feature Class in Mobile Geodatabase
