In our environment, we prefer to have users Enable/Disable editing from the Edit tab. We are using traditional versioning in ArcPro 3.1.4. We have found when using Calculate Geometry on the Attribute Table to calculate lengths the update occurs in the table and the "Save" button remains greyed out. If a user, does not physically disable the Edit Session or perform other edits that require the "Save" button, the changes do not stick. These changes could either automatically save so that if a user closes out of their project without disabling the "Edit" button the edits are still saved or require the "Save" button to commit the changes to match normal editing workflow.
