Calculate Field — Exclude un-editable fields from Field Name parameter
1646
02-26-2024 12:51 PM
Status: Implemented
Bud
Legendary Contributor
ArcGIS Pro 3.2.2; File Geodatabase
In the Calculate Field tool, fields like Shape_length are available in the Field Name parameter drop-down. However, Shape_Length is not editable and will throw an error if the user tries to do a field calculation on it.
Is there a reason why uneditable fields need to be included in that pick list? Or can they be excluded?
ERROR 160143: Field is not editable.
3 Comments
MargaretCrawford
Hello @Bud, This is a good idea, you shouldn't have to run the tool to find out there was an issue.
Our team is going to keep this idea under consideration for a future release of Pro.
-Margaret
DrewFlater
This is in the Pro 3.5 Beta.
MargaretCrawford
Hi Bud, This idea is implemented in ArcGIS Pro 3.5.
The Calculate Field tool's Field Name parameter will exclude read-only fields.
https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm#GUID-EEB6223B-19DD-...
This includes fields like Shape length, Shape area, Global IDs, and editor tracking fields to avoid getting an error when you run the tool.
