Bring back the Identify Tool from Arcmap
3430
9
02-06-2024 12:03 PM
Status: Open
jakek
Please bring back the ID tool from Arcmap.  It was much easier to use and select features to ID.  It becomes cumbersome to select several features spread across the map and add to a the pop-up like it is in Arcmap. Please consider this enhancement!
9 Comments
ClayDonaldsonSWCA
this already exists in arcgis pro and you can control if it returns all layers, top-most, etc.
Navigation command Description
Explore
A multifunctional tool for navigation and feature identification. This is the default tool when you open a new or existing project. Left, right, and wheel mouse buttons all have built-in capabilities as follows:
  • Left-click—Pop-up identification for a feature
  • Left drag—Pan in 2D and 3D
  • Middle drag—Pan in 2D
  • Middle roll wheel—Zoom in and out
  • Middle click and drag—Rotate and tilt (3D only)
  • Right hold—Continuous zoom
  • Right-click—Context menu for additional tools
jcarlson
You can also hold the C key and do an identify-click any time, regardless of what tool is active.
jakek
Still not like Arcmap.  But, I did discover: 1. using explorer finger, select feature to ID, popup opens with results  2. To add to existing popup: 1st hold down ctrl key, then press and hold shift key  3. then draw box around additional features to add to the popup.  In Arcmap, pick feature(s) to ID, then to add to the popup, just hold down the ctrl key (or just hold down shift key) to add to the popup, single pick or box.  Also, ID tool in Arcmap is independent of other tools which makes it easier to manipulate selecting features.
SeaRM
jakek, you can try to use the Identify Pro of XTools Pro for ArcGIS Pro.
geodoozer
I agree with JakeK.  I would like to see Identify with the draw rectangle to identify all features in this area back.  It is really cumbersome making several layers selectable, selecting a rectangle of features, then opening each attribute table in turn and filtering to the selected features to see what is there.  Further, the lack of rectangular identify is going to be tricky for our novice users.
KoryKramer
@geodoozer for "rectangular identify" have you tried holding down Ctrl and drawing your rectangle with the Explore tool?
JayColeman
I would love to be able to select which layer I'm identifying. I know you can choose "Selected in Contents" however I don't always have the layer I want to ID selected and it adds unnecessary clicks to the operation.
JayColeman
If ESRI allowed the "Selectable Layers" option to work with grouped items and rasters this would be fixed.
geodoozer
Thanks Kory!  That's helpful.
Sometimes I would love identify to be possible on a layout view without having to first activate the map.
