BIM file to gdb: avoid empty output
1325
12-13-2024 01:24 AM
Status: Closed
KarlTian1
Hello,
When using BIM file to gdb it will create a standard index of all these feature classes,  but many of them is completely empty, it's extremely hard to use, May I suggest to add a option only create feature class that have something inside, just ignore the empty ones?
Thank you!
Karl Tian
2 Comments
DA_BIM-GIS
hello @KarlTian1
This behavior was done to help with the downstream workflows. When you create a builing layer you could use the Remove Empty Layers to have "cleaner" building layer
Best regards,
D
MichaelDavidsonPM
Status changed to: Closed
