Batch edit formatting of multiple table frame fields across multiple table frames
1474
05-22-2023 10:00 AM
Status: Open
wayfaringrob
Honored Contributor
Right now if I multiselect table frame fields in the TOC and then go over to the Element pane to align the text to the left, I can't. Upon clicking Apply, my multiselection turns into a single selection, and the edit is only applied to the first field I selected.
Would be great if you could apply formatting to multiple fields at once as may be expected, thanks.
4 Comments
AubriOtis
Just to clarify, you are asking about applying formatting to multiple fields in different table frames? This should be working for fields within the same table frame.
wayfaringrob
@AubriOtisyes, please see screenshots - these are in different table frames
AubriOtis
Status changed to: Open
AubriOtis
Thanks @wayfaringrob I updated the title to reflect that, since there is a scenario where editing multiple table frame fields works, they just need to be in the same table frame.
