Arcpy -- Correctly display data source
570
11-05-2010 05:58 AM
Status: Closed
JOHNGODDARD3
When using the arcpy funtions MakeRasterLayer and SaveToLayerFile, the resulting layer file does not correctly display the data source under properties.  Although the layer is usable and points to the correct data, the user will not be able to verify the source.
1 Comment
HannesZiegler
Status changed to: Closed
Thank you for your submission, and apologies for the very late response. Your post was only recently redirected to the correct ideas exchange for Python/ArcPy ideas.
This submission appears to be a bug report. Please note that idea Exchanges are not the right place to log software bugs. However, just because it isn’t the right fit as an Idea does not mean that we aren’t here to help.  Bugs and crashes should be logged with Technical Support. Support will help you establish a reproducible workflow that will then help us debug and address the issue.
Note: To contact Technical Support, you need to be an authorized caller. See Why can't I submit cases? (Or, How I became an authorized caller and reported my issue) for more information.
Regarding your bug report, I was unable to reproduce the issue in ArcGIS Pro (3.4 dev build), so it appears to have been resolved at some point.
