ArcGIS Pro indexing Enterprise SDE content to improve project speed
1296
07-29-2019 07:00 PM
Status: Open
JamesBotterill4
Are you experiencing slowness initially opening a project in ArcGIS Pro?
Do you have a large amount of Enterprise SDE content in your map views / layouts?
Then consider unticking the "Skip enterprise database connections" under ArcGIS Pro > Options
My suggestion to ESRI is:
Change: update the hover text or add a popup when users add a SDE databases connection to consider indexing options
Why: as above, the "skip" enterprise connections is ticked on by default, so the user needs a reminder to consider indexing SDE content should they have more of it say compared to just file geodatabase
ArcCatalog
3 Comments
AlisonMynsberge
Interesting...  Does this really speed things up? @KoryKramer
KoryKramer
Indexing is a consideration when troubleshooting performance issues as described in Troubleshooting Performance Issues in ArcGIS Pro
Switch to the Indexing tab (learn more about indexing options).
  • If you know where your data is, or you rarely have reason to search projects, you can turn indexing off.  Try turning off indexing, or otherwise reschedule it to occur during times when you’re not using your machine.
KoryKramer
To add to the response above https://pro.arcgis.com/en/pro-app/latest/help/projects/index-project-items.htm#GUID-07D6A013-47CB-43... indicates that by default the contents of enterprise geodatabases are not indexed.
