ArcGIS Pro: Update Metadata
1229
04-13-2018 07:50 AM
Status: Implemented
DeidraHunter
If I am working with older data, either my own or something I've downloaded, I get the warning "This item has authored FGDC metadata that must be upgraded to ArcGIS metadata format before it can be used in ArcGIS Pro." Since there is no way to update the metadata within Pro, I have to pass it through ArcCatalog to "Update Metadata" before going back to Pro. It would be nice if I could update Metadata directly in Pro.
1 Comment
AletaVienneau
You can upgrade FGDC CSDGM-format metadata in ArcGIS Pro. The workflow to use is documented in the help topic Upgrade metadata to the ArcGIS format. This capability has been available since the ArcGIS Pro 2.2 release.
