ArcGIS PRO: Reorder and Group Items Quick Access Toolbar
3394
6
05-31-2018 08:02 AM
Status: Open
SeanHlousek
Can you add the functionality to reorder items that we have added to the Quick Access Toolbar?
(This is in the product plan to 2.2)
EDIT:
Can we include the ability to group various QAT items together, (before or after they have been re-ordered)?
This would better serve specific workflows.  For example you could group together a bunch of "Editing" items into one Quick Access Toolbar group, then another for other similar functions.
6 Comments
KoryKramer
Reviewed... the Re-order part of this idea is In Product Plan since that is built into Pro 2.2 already.  Yay!
Adding groups to the Quick Access Toolbar is not.
Maybe you just want to change the idea now to focus specifically on adding groups to the QAT?
SeanHlousek
Thanks Kory,
I edited the idea to reflect grouping specific items together in order to better facilitate various workflows.
-Sean
KoryKramer
Thanks, Sean.  For now, make sure you don't overlook that you can create your own tabs and groups within your custom tabs with tools and commands that move through a workflow.
Customize the ribbon—ArcGIS Pro | ArcGIS Desktop
DanielWhitworth
I actually argue that the need isn't met. The user shouldn't have to go into edit menu to rearrange. We should be able to drag them around on our toolbar. We should also be able to have groups we create in the menu (so I can have the common edit together in a little boxed outline (without having to waste the whole screen using the ribbon). Additional quick access toolbars would be awesome.
wayfaringrob
Would love to see a separator for quick access tools. I have a growing number of tools up there that I'd love to separate into categories - selection/navigation, windows, layout, etc.
jcokin1
@wayfaringrob your comment above regarding separating / grouping parts of the QAT should be its own idea.
The ribbon is ArcGIS Pro was not executed as well as it could have been. The least ESRI can do for us, is allow us to properly customize the QAT and save us some time. The shear number of clicks to execute and dig through the ribbon is mind numbing at times.
Here are some screen captures below.
You can see dividers that help group the various functions. This would help out new and old users and the most important parts of a companies workflow as they can customize the QAT to their needs.
ArcMap toolbars with dividers
QAT with dividers (Requested Enhancement).
@KoryKramer let us know if this already out there. I looked up and down the ESRI Community forum and did not see anything 🤔
FYI - Here is the link by @DrewFlater for the QAT toolbar you can download
ArcMap-Style Toolbar for ArcGIS Pro by  @DrewFlater
https://www.arcgis.com/home/item.html?id=982ee4e5434d46e6a94209fe6bc875bc
Thanks everyone!
