ArcGIS Pro - Map Series Problem
1500
01-08-2019 03:15 AM
Status: Closed
MathewAzzopardi
Coming over to ArcGIS Pro from many years of ArcMap, Data Driven Pages never presented this problem to me, but on Map Series in Pro, the labels do not appear the same in the PDF as they do on screen, sheet per sheet.
As per attached, you can see I've highlighted the labels which have moved on export to PDF, which may not look like a huge problem, but then the text to the right highlighted is out of the map extents so this then does pose a problem.
However, there are 12 sheets, and this problem only occurred on 4 of them, although all 12 sheets were exported altogether.
Any ideas why? Or workarounds?
Tags (1)
2 Comments
KoryKramer
Mathew Azzopardi‌ This looks like a question that would best go to the ArcGIS Pro‌ space rather than an idea.  Could you please move it to a question in that space?
If you need help troubleshooting and have support, you could open a case to investigate the issue.
Thank you.
KoryKramer
Status changed to: Closed
Closing this as an idea. If the problem persists, please post to the ArcGIS Pro questions board for help from Esri Community members or contact Technical Support to troubleshoot with a support analyst.
Thank you!
