ArcGIS Pro - Import MXD: Choose what to import
768
11-02-2017 07:44 AM
Status: Open
GreggRoemhildt1
When I import an mxd, it usually creates a map - Called Layers (whatever the dataframe was named) and a layout named the same as the mxd. Sometimes I just want the map, sometimes I want the layout, sometimes but not always I want both.
Maybe import Map could be a gp tool with the options of "What to import" as a parameter.
Thoughts?
Tags (1)
1 Comment
RTPL_AU
Currently, when using the Import Map option, Pro will import the full MXD with both maps/dataframes and the layout.
I quite often only want the maps/data frames.
Please add an option to the Import Map workflow to import only maps or scenes and not the layout.
