ArcGIS Pro: Creating Coded Value Domains - Enter to go to Next Row as in ArcMap
1294
08-27-2019 06:16 AM
Status: Closed
CherylTrine
When creating (or adding values to) a coded value domain in ArcGIS Pro 2.4.1 (and the previous versions), adding new coded values is awkward.  After adding one row and hitting ENTER, the next row is highlighted but you have to select the cell to start typing -- an extra, awkward click, especially if you are adding many values.  Please make it like ArcMap where you enter one row, hit enter, and you can start typing on the next row immediately.  (This is a similar issue to the problem with attribute table editing before 2.4)
Current workaround is to use tabs; ENTER should work the same way!
2 Comments
SSWoodward
SSWoodward
Status changed to: Closed
Thank you for this idea.
In ArcGIS Pro's Data Design Views and Attribute Tables, using the `Enter` key finishes data entry by removing the active cursor.  To continue entering new domain coded value pairs in the domains view, the `Tab` key is the key that must be used.
Changing to `Enter` instead of `Tab` is not currently on the roadmap for the Data Design Views in ArcGIS Pro.
