ArcGIS Pro 2.6: Allowing drag\drop while working with environment,
1316
08-04-2020 07:46 AM
Status: Open
JamalNUMAN
Legendary Contributor
It would be nice if drag\drop property is allowed while working with environment.
5 Comments
KoryKramer
Thank you for submitting this idea, Jamal!  You are correct - it looks like the Environments dialog is modal and blocks the UI while it is active, thus preventing drag/drop.  So you have a valid idea.
It does appear that you can drag/drop from the file system into the dialog which might help a little bit, but does not address the need to work directly from the Catalog pane.
JamalNUMAN
Is this planned in 2.8?
KoryKramer
Hi Jamal,
The status will be updated if and when it is being considered.  A change to Under Consideration or In Product Plan will indicate movement on our side as described in the ArcGIS Idea Statuses document.
JamalNUMAN
Not even in 2.8.1
JamalNUMAN
Still not considered!
