ArcCatalog Show/Hide Hidden Files
3216
08-24-2010 09:29 PM
Status: Implemented
MarcBate1
I'd like to have an option for ArcCatalog to show or hide hidden files.
It is showing hidden system files, such as Thumbs.db, which is just the Windows Explorer thumbnail cache file and should even be showing up in ArcCatalog.
It could also honor whatever you are using for your Windows Explorer show hidden files setting.
5 Comments
OwenFritch
A custom extension to our ArcGIS system uses the Windows OS 'hidden file' setting as a way to get around the locks placed on .gdb files within an ArcMap session -- flagging files for deletion after the session is closed, via an automatic housekeeping process.  This process would work much better if ArcCatalog indicated which files are hidden in this way, so we know that they are files that have been marked for deletion by our system.
NaicongLi
NaicongLi
KoryKramer
This is implemented in ArcGIS Pro 3.3. See Your Ideas in ArcGIS Pro 3.3 for a full list of all user ideas you can look forward to! And be sure to check out the release blog and what’s new help topic and video to learn more about all the new features and functionality in the release.
AlfredBaldenweck
Hi, we just upgraded to 3.3. I'm glad that we have the option to see hidden files now, but is there a way to turn this setting off?
