ArcCatalog's Set Data Source as a geoprocessing tool
1005
10-14-2010 08:08 AM
Status: Closed
AitorCalero_García
Sometimes you need to change the datasource in a MXD file for a large number of files. When using this tool inside ArcCatalog, the program is completely unusable until the process finish.
One good improvement would be to convert this tool into a geoprocessing tool to be run in the background. This way you will be able to go on with your work
1 Comment
MargaretCrawford
Status changed to: Closed
At this time there is no plan to offer this capability as a system geoprocessing tool. However, ArcGIS Pro has enhanced capabilities for updating your project data sources using the Catalog View. https://pro.arcgis.com/en/pro-app/latest/help/projects/update-data-sources.htm#ESRI_SECTION1_291CD5B...
