ArcCatalog - Restore Default Column Widths Option
1411
12-04-2014 03:31 PM
Status: Closed
SarahWillett
ArcCatalog should have a Restore Default Column Widths option.
See the following screen captures.
0EME0000000UUMW
0EME0000000UUMb
Can we please fix/enhance ArcCatalog to resize to the default colum width similar to ArcMap when it comes to viewing the attribute tables?
Thank you.
2 Comments
AletaVienneau
Status changed to: Closed
ArcGIS Desktop, which includes ArcCatalog, retired March 1, 2026 so we won’t be considering this idea.
For reference, in ArcGIS Pro, when you preview a table in the Catalog view on the Details panel with the Table tab, columns start with the same default width as when you open a table from a map's Contents pane. You can also open a table in a separate window directly from the Catalog pane or Catalog view, and the resulting table behaves in the same manner as when a table is opened from a map.
Thank you for taking the time to share your ideas. They help us to continuously improve the software. We look forward to seeing what ideas you have for ArcGIS Pro!
