Apply same decision to several selected topology rules
7897
15
03-30-2021 02:57 PM
Status: Already Offered
lbraceromarre
Hello:
I think it will nice to apply exceptions and solutions to several topology rules at the same time when running the Edit Inspector. The idea is that from the Edit Inspector Window, you should be able to select several rules, right click on the rules table and  click "Marks as Exception" or other suggested fix and apply the  to all the selected rules.
This will avoid to select each rule individually in the case the user wants to apply the same decision.
Thanks.
(view in My Videos)
15 Comments
LJackson29
@Scott_Harris You indicated this is not the expected behavior when responding to my above post. We are using a Portal service with branched versioning to edit our layer including reviewing topology. Could this be the issue?
Scott_Harris
@LJackson29 I can't reproduce the problem you describe
Here I'm marking multiple errors as exceptions and clearing the exceptions without an issue. This is a branch version feature service in 3.0:
Did you reach out to Esri Technical Support?
LJackson29
@Scott_Harris Scott thanks for your response and video. That is not what we are experiencing. When we select multiple errors and try to mark them all as an exception it only does one when using the Fix window, and we tried both manually selecting errors on the map as well as in the table. We just got off the phone with ESRI customer service and they were not able to resolve the issue yet. Two questions: 1. What version of portal was your service published in, and 2. I noticed that your errors are "must not have gaps", while our error are "must not have overlaps" - I can't believe that would the difference, but just want to make sure.
Thanks!
Scott_Harris
@LJackson29 Please continue to work with Esri Technical Support. I have a hunch I know what's going on. I'll be in touch with the analyst that's working on your case.
LJackson29
@Scott_Harris Many thanks - it is case # #03197951
