Allow users to remove Elevation Surfaces from TOC in a map
1555
06-13-2023 03:51 AM
Status: Open
DuncanHornby
MVP Notable Contributor
Latest version of ArcPro 3.1.2 allows you to add elevation datasets to Elevation Surfaces, you can remove the dataset but currently it is not possible to remove the Elevation Surfaces node in the TOC tree. Please add the ability to remove that too. Example is shown below.
Example showing how you cannot remove the Elevation Surfaces nodeExample showing how you cannot remove the Elevation Surfaces node
1 Comment
JohnWright
I second this request.  I cannot locate any way to delete it from the TOC.
John
