Allow Snapping Environment Window to be a tab in the Table of Contents
896
06-25-2010 07:58 AM
Status: Closed
BradStump1
Please allow a user to choose to display the Snapping Environment window as a tab in the Table of Contents and to set the order in which it appears much like was done with the Selection tab a couple releases ago.
The Snapping Environment window quickly becomes large when more than a few layers are present in the map thus either taking up valuable screen space or requiring it to be turned on and off repeatedly.  Alternatively, if kept small and docked under the TOC then both windows have a smaller viewable area requiring a user to continually scroll up and down the lists as snapping needs or TOC properties (FC display and/or selection) change during editing sessions.  Allowing the Snapping Environment window to be a tab within the TOC would allow the TOC to remain full-sized and allow switching to/from the Snapping Environment window with a single click of the mouse.  This would really help improve my editing efficiency.  The dynamic snapping (right click, etc) just isn't versatile enough.  I know this request has been made multiple times over the last several releases so I'm hopeful it can soon be incorporated into a future release.
2 Comments
by Anonymous User
This is a great idea!
ValeriaChavez
Status changed to: Closed
Hi @BradStump1
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application.
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
