Allow Rectangle Textbox to Grow/Shrink and Vertically Justify Text
25641
44
01-09-2015 01:04 PM
Status: Implemented
LucasMurray2
Allow the rectangle textbox to grow or shrink based on the text within the box.  When creating data driven pages, I sometimes add long text to describe the data in the map.  If I size the textbox for the longest text and the text shrinks for one of the maps, I'm left with a large blank space between the bottom of the text and the bottom border of the box.
Also, within a rectangle textbox, allow me to control the vertical justification of the text.  Currently, it's only top justified.  I'd like the ability to make it center or bottom justifiy.
Thank you.
43 Comments
RichardHowe
In product plan 🥳🥳
If we could expedite that it would be great. It's only been 8 years.
For another use case I'll add creating a table on a map frame that isn't a data table and can't be achieved via a table frame (e.g. has excel style functionality of merged cells etc.).
PhilLarkin1
Auto Grow/Shrink would be great for automating map production. The alternative is writing python exceptions for all elements that might need more space than exists in a layout.
Tracey_Rossato
This is so annoying. I now have to create a separate text box over a rectangle just to achieve a vertically centered label. Surely, this can be addressed.
wayfaringrob
Agree with others that Esri ought to be more robust with its functionality and responsive to the needs of users. 9+ years and pages and pages of customer advocacy to implement simple text alignment options is just insane. Priorities seem really backwards. It's not just this feature that suffers from this lack of attention, but those should have been there from the beginning. Let's get it done.
Christoph_Höser
This will take more than 9 years? Considering all the other features in ARC GIS Pro, the entire software package must have taken 3,500 years or more to develop.
ESRI, do you even listen to customers?
KFung_TLC
Good Question! Who is ERSI's customers? Do ESRI even consider those who heavily involved in map production as customers?
In wonder in ESRI's echo chamber of product development teams, did our voice even exist?
PaulNicholls_Nambucca
Can't believe this is still a known issue that hasn't been fixed. Please fix the issue and allow text to be vertically aligned within a text box!!!
mthompson
There do now seem to be several different text types that you can put into layouts. The "Rectangle Text" still will not let you vertically justify for some reason, but there is a "Straight Text" option, where the bounding box is tight to the text, that you could at least combine with a rectangle shape, vertically align, and get a similar result. Not sure if that has always been there, but if it was, I certainly didn't notice it in earlier Pro versions.
wayfaringrob
@mthompson  yeah, that's always been there, but not ideal. You have to put in manual line breaks...
wayfaringrob
Also @KoryKramer I am seeing this is marked implemented, is that true? Which version?
